@freysa/saf
0.0.13 • Public • Published
README
Run examples
Navigate to examples directory.
Example server
pnpm dev
Token transfer using Private Key signing and Safe Signing
For Safe Signer make sure to you have a running gRPC signer server. A mock server can be started using. It will sign a safe signature using the private key in environment variable PRIVATE_KEY.
pnpm grpcMockEthSigner
To execute sample transfers
pnpm transfer
Build from source
pnpm install
pnpm build
Tests
There are unit tests as well as integration tests some of which requires API token. Make sure to create .env.test with environment variables required for the integration tests.
To run tests
pnpm test
Logs
socat TCP-LISTEN:12345,fork -
Deploy NPM package
Update version in package.json
npm login
pnpm build
npm publish
Readme
Keywords
none
Package Sidebar
Install
npm i @freysa/saf
Weekly Downloads
16
Version
0.0.13
none
Unpacked Size
16.1 MB
Total Files
93
Last publish
Collaborators
  • asdfx111
  • gustavofrings
  • behelitx
  • 0xdemureness
